Vandelay Industries
- Apr 8, 2008
- Nashwaak Valley, NB
- 2013 Nytro XTX
Just finished changing the top gear in my chaincase to the DMC heavy duty gear. These four small screws were left in the parts tray at the end of the job. They are 3/8 long, Phillips. Anyone recognize them and where they go?
A hint: There was some little bits of aluminum on the threads of the screws.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I dont know of any Phillips screw heads on the sidewinder unless someone changed out the torx head screws.
Fords4life
- Dec 7, 2021
- South Dakota
Do you have a "buddy" "helping" you? Playing a joke on you, no i have not seen anything like that eather. Working on a gear swap as i speak, so will look closer, if i find anything will report it.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I just opened up my chaincase and replaced top gear with DMC 22. I can assure you those did not come stock on a sidewinder.
Vandelay Industries
- Apr 8, 2008
- 2013 Nytro XTX
I'm pretty sure they have nothing to do with the chaincase, but maybe something else nearby?
BV1200
I just put my buddy's chaincase back together. Nothing takes those screws. On a winder
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Maybe someone replace the 4 torx screws that holds the plastic over the gas tank with those?
Turboflash
- Mar 18, 2019
- Southern MN
If I'm thinking of the ones you're referring to, those are the 4 screws that go into the spars holding the gas tank in; well those spars are steel not aluminum. So if you say they had aluminum on them, they couldn't have come from the "dash".
- 11K
- 33K
- 10K
