nutnbut4stroke
- Feb 3, 2013
I have a 07 attak gt and was looking to put extrovert drivers on it. I see they make different pitch and tooth designs, Who has put these on there sled? How do you know which pitch you have, and Tooth count I would assume would be the same as on the original driver? any feedback is appreciated..pros and cons please and thanks.
apexmcneil
- Sep 18, 2013
- Halifax Nova Scotia Canada
- 2008 Yamaha Apex LTX
Upgrade GYTR Dual Rate shocks,
Ohlins Rear
Oillite bushing kit
Powercoated Rear skid
Snow Trackers
2.52, 9 tooth for stock yamaha tracks..
i just put a new exo driver on my sled.. Great upgrade to ensure no more ratcheting.
nutnbut4stroke
- Feb 3, 2013
thanks, what brand and where did you purchase yours from?2.52, 9 tooth for stock yamaha tracks..
here in Canada, you can order through your dealer if he has gamma/motova/kimpex access. I bought the set for my brothers war and my old one at royal distributing.
in the us, tracks usa or Hartman would be a good place to start. there are others but those are the 2 names I know.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Just buy a 2010 Apex shaft and newer with drivers, you just have to cut the shaft off and drill and tap the threads. easy upgrade.
apexmcneil
- Sep 18, 2013
Ohlins Rear
Oillite bushing kit
Snow Trackers
why would you need to cut anything off the axle? I just put a 2012 axle in my 08 and it fit fine??
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
10 and newer have a extra bearing in the chain case cover that the older ones don't have. plus the shaft diameter is bigger on the newer ones.why would you need to cut anything off the axle? I just put a 2012 axle in my 08 and it fit fine??
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Was your 08 chain case updated? A 12 shaft is longer as mentioned above.
I have several updated shafts with extros. I can modify one to fit if you still need one.
apexmcneil
- Sep 18, 2013
Ohlins Rear
Oillite bushing kit
Snow Trackers
i have it all together already, and it fits perfect, with the 08 chain case. I have the speedo bearing in place, and cover back on, and axle is centered properly under the sled...?? unless, the Axle i got wasnt for a newer apex and i mus-interpreted what it is.. What year did the axle become larger?
