**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
money not being an object...Id be a mcx client for sure...Ive never heard of an unhappy customer
fxnytroxtx
Guest
Anyone know how much mcx 180 kit coasts?
bwwelke
Well I found super charger kit for $3,300.00 Question being. Since I am a flatlander does anyone know what kind of H.P gains this kit would have. Also can you change the pulleys around to run the 11 PSI?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
bwwelke said:Well I found super charger kit for $3,300.00 Question being. Since I am a flatlander does anyone know what kind of H.P gains this kit would have. Also can you change the pulleys around to run the 11 PSI?
well confuscious say...man who walk around with hands in pockets feel cocky!
he also say...act in haste ....repent in leisure....or was that my dad?
you best know what your buying before you go off half cocky bro...
you ait running 11lbs of boost without some serious mods...grab them ankles....
p.m. me and tell me what youre about to do and I can help
bwwelke
Here is a installation manual for supercharger I found. It has some good pics of install at the bottom.
http://www.mountainperformance.com/File ... -small.pdf
HYFLYR
If you want to run 11psi you will need 26/29 pullies and the cold air intake with your breather off the throttle bodies ran to the intercooler at sea level. Its doable but on 104 octane on a stock motor.Ive ran this setup for 2 years now on a super. Works well and is very fast.
SledFreak
- Feb 7, 2005
- Ontario. Canada
If you don't know the answer to this, you should not be buying it.
bwwelke
I haven't bought this yet but that was the price on Port yamaha's Website.. Thought it sounded like a good deal but I'm starting to think otherwise.
bwwelke
Well I talked to MPI today, good news the super charger it will work for us flat landers and yamaha is working on a fuel programer for us right now. The only thing we would have to do is change the pulley because it would be about 9 to 11 psi boost as it is right now. Plus you could always add the intercooler later down the road for more power.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes...the flatland kit is being tested...but as conservative as yamaha is you can bet it will be next year at the soonest...
shadow44
I think after hearing Ulmers turbo kit ( and him coming up with an even cheaper setup ) i'd go that route...even with an Excell muffler it sounds stock..I was quite impressed!
welterracer
I vote ulmers.. I should because i do the ceramic coating on the manifolds , down pipes and turbos.. I kno they are high quality..
- 10K
- 9K
- 25K
