Specs from the 2018 Technical Update Manual-2018 SW LE:
(Fox HP Gas Coil‐Over QS3R)
ADJUSTMENT RANGE FRONT
Spring Rate 95 lb/in
Spring Installed Length (Preload)
Front Travel 7 in (177 mm)
Std. Compression Damping 1 of 1 – 2 – 3
Std. Rebound Damping 12 Clicks Out 1 ~ 20 Clicks
CENTER SHOCK
(Fox HP Gas Coil‐Over QS3)
Spring Rate 135 lb/in
Std.Compression Damping 1 of 1 – 2 – 3
REAR SHOCK
(Fox HP Gas QS3R)
Spring Rate 18.5 lb/deg.
Std. 3‐Position Cam Adjuster (Preload) M of S – M – H
Rear Travel 15.5 in (394 mm)
LIMITER STRAP STD ADJUSTMENT RANGE
8JP‐G7495‐10 Hole 1
1 ~ 3
(min preload:
1/8‐in on shock)
