beetongrizzly
- Oct 12, 2014
- Beeton Ont
- 2015 ltx deluxe
Thought I saw a post on here with the factory settings from yamaha for an ltx le. Not able to find it now, can any one help
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Are you looking for susp stock settings?
I got this if that is what you meant. -Dan
Specs from the 2018 Technical Update Manual-2018 SW LE:
(Fox HP Gas Coil‐Over QS3R)
ADJUSTMENT RANGE FRONT
Spring Rate 95 lb/in
Spring Installed Length (Preload)
Front Travel 7 in (177 mm)
Std. Compression Damping 1 of 1 – 2 – 3
Std. Rebound Damping 12 Clicks Out 1 ~ 20 Clicks
CENTER SHOCK
(Fox HP Gas Coil‐Over QS3)
Spring Rate 135 lb/in
Std.Compression Damping 1 of 1 – 2 – 3
REAR SHOCK
(Fox HP Gas QS3R)
Spring Rate 18.5 lb/deg.
Std. 3‐Position Cam Adjuster (Preload) M of S – M – H
Rear Travel 15.5 in (394 mm)
LIMITER STRAP STD ADJUSTMENT RANGE
8JP‐G7495‐10 Hole 1
1 ~ 3
(min preload:
1/8‐in on shock)
CENTER SHOCK
REAR SHOCK
(Fox HP Gas QS3R)
8JP‐G7495‐10 Hole 1
1 ~ 3
(min preload:
1/8‐in on shock)
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
interesting it states hole 1 on limiter whereas mine and most others state came on hole 2 (hole 1 hidden under washer)?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yeah I think maybe a couple things might be off from that copy/paste I got.interesting it states hole 1 on limiter whereas mine and most others state came on hole 2 (hole 1 hidden under washer)?
beetongrizzly
- Oct 12, 2014
- Beeton Ont
- 2015 ltx deluxe
thanks that was what i was looking for
- 8K
