Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Engine oil does note reach this bearing? Are you sure and if so, what type of grease have you used on this bearing as I am sure it see fairly high temps and is subjected to gases and contaminants from combustion as the oil is?
dubla92
The inner bearing is lubed by engine oil. The outer is sealed on both sides. I would use Iso Flex bearing grease like Skidoo does in their cranks. I have investigated a new bearing and the grease is white just like Iso Flex.
