fault code
jbsr
Kingston, Ont.
When I power up it shows code 15. TPS\
When I go to diagnostic mode 1 it shows a low of 2 to a high of 34
The manual says it should show much higher numbers.
All 3 apexes in my shop show the same.
Is the manual wrong?
Diagnostic mode 62 is supposed to clear codes but the manual contradicts itself in the directions on how to clear codes.
The code 15 may have been there since I had tors issues after MPI install.
Any ideas?
unplug the MPI controller and put it back to stock you will see your 15+ low to 95+ wot ,it will show these low readings with the other controller hooked up and you can't clear any codes with mpi controller hooked up,it has to be stock,but any ways your gonna see code 15 all the time and it will go away but if you release the throttle from a wot romp fast the tors will kick in, so jump out the tors and it will show 15 when you turn on the key but will go away and run ok and wont die after quick throttle releases.
