Few questions about a 1997 Yamaha VMAX SX 700cc
atmosfear
Gwinn, Michigan
Before I left for a ride today I cleaned off the head, put three new plugs in, and tightened them all the way up. About 20 miles down the trail I checked them to see if everything was all fine and dandy and I noticed some oil/grease splashed down from from two of the plugs. Why is this happening?
Also I know this should probably go in the suspension forum, but I thought I'd just put it all in one post. Anyways, my dad just recently rebuilt my suspension (stock suspension). It's been a good 300-400 miles and I have already tore up a hyfax. This can't be right.... is there some adjusting that needs to be done? What do you think?
Thanks in advance for any help. Take it easy.
How did your dad reset the suspension after he rebuilt it. In Muni Chad had pulled his limiter up all the way, and made his hyfax wear worse. Problem was he didn't take the preload out of the spring, and the sled was ridding on the bend of the rail like a teter totter. Where is it wearing at the most. Where is the oil grease at on the plugs. Maxdlx
