So I wonder, if a guy put the elements from a 06 apex on a 08 Nitro , would you get some results?. I looked at the 06 handlebars, with a riser a guy might get them close, but I really don't wanna burn anything out electrically. I'm also wondering if a person added another HOT wire BEFORE the switch to aid in power possibly.parkindale said:I've had the 06 bars on mine for about 2 weeks & they work great,it probably will void you warrantee if something should happen ,but at least mine hands are warm.m2c And yes the bars are slightly different & you will have to install the hand guard brackets upside down so they wont rub on the tank.
I believe the 2006 bars are a bit thicker so a small riser would work just fine & if your consernd about hurting the electronics just dont turn them up too high or add a resistor.Topgun said:So I wonder, if a guy put the elements from a 06 apex on a 08 Nitro , would you get some results?. I looked at the 06 handlebars, with a riser a guy might get them close, but I really don't wanna burn anything out electrically. I'm also wondering if a person added another HOT wire BEFORE the switch to aid in power possibly.parkindale said:I've had the 06 bars on mine for about 2 weeks & they work great,it probably will void you warrantee if something should happen ,but at least mine hands are warm.m2c And yes the bars are slightly different & you will have to install the hand guard brackets upside down so they wont rub on the tank.
