phazerdrew
Ive racked up almost 500 miles on the sled and its only a week old
Im gonna go ahead and change the oil myself just wanted to see what oil people are using.. Ive always had awesome luck with amsoil or motul in everything I own most likely will go with that.. My dealer misplaced the owners manual so what weight oil should be going in the sled, and does anyone have any tricks to share to make the oil change a little faster
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I use Opti oil, 5w30, Yamaha say to use 0w40 I think. The company I work for is an Opti oil distributor so I get a good deal on it and if you use their oil they will double your engine warranty. You cant beat that with a stick.
Ow-30 and we use Castrol Syntec
Get a k/n oil filter it has a nut welded on the end and will make life alot easier to remove the next time
Otter
Otter
