09nytro
I think it's Hayes but not sure didn't really look.....
dfroster
- Dec 18, 2003
- Kronenwetter, WI
- 2022 Arctic Cat Thundercat EPS
So the 7000 and Viper motor will be produced in US by Cat to Yami specs? I understood it was to be built in Japan and shipped to Cat. Way too much conflicting info.
Alatalo
- Jan 11, 2005
If they will assemble the engines in Thief River Falls, then I am seriously worried...
09nytro
That is the funniest thing I have read in a long timedfroster said:So the 7000 and Viper motor will be produced in US by Cat to Yami specs? I understood it was to be built in Japan and shipped to Cat. Way too much conflicting info.
Now let me ask ....Do you think that would really happen? Let me answer that....NO.......
dfroster
- Dec 18, 2003
- Kronenwetter, WI
I don't know what to think anymore. Doesn't matter that much either. I'm interested in the Viper and the 7000 but sledding thoughts are slowly fading away into hibernation until next fall.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Easy way to end speculation, wait till the production models come out.
Alatalo
- Jan 11, 2005
As somebody already said, there is conflicting information and Yamaha needs to come clean about this long before production starts. Will the SR Viper engines be assembled in a Yamaha plant and then shipped to Arctic Cat...? Or, will the SR Viper engines be assembled by Arctic Cat...?
In my opinion, the answer to this question could be the deal breaker for more than one potential customer. I and many others could potentially live with a chassis built to Arctic Cats normal fit and finish. But a fine tolerance high performance four stroke engine...? Assembled by some butcher in Thief River Falls...? No way...!
Nytro40th
- Sep 19, 2007
Like I said we have to wait and see, I doubt Yamaha will discuss the matter, but I see the point everyone is making.
grader
the engines are from japan, the exhaust,fuel injection, and ecm are added by cat. this is why it has the 02 sensor on the exhaust. this also means that it will be tuneable eg. fuel flow, timing, etc just as the cat turbo is from the aftermarket suppliers. with this setup, the potential for mods is wide open.
YamBam
- Feb 23, 2012
- Michigan
- Sidewinder LTX-LE 2018
Crazy thread. It is obvious that Yamaha has given up the old fit and finish for a cheaper quality sled. Instead of developing a chassis to meet Yamaha standards they bought AC subquality chassis and stuck their motor and clutches in it. They wanted a cheap way to get a new chassis. Anyone check to see if it has a single or double chain in it to make sure it does not break? How about a strengthened tunnel to make sure it does not bend? These were both intial quality issues, plus many more, with this chassis from AC. Initial marketing spin from Yamaha was that they would be overseeing the production in the AC manufacting plant. Hah, alot of good that did with the fit and finish. What a joke. How dumb do they think we are? Thank goodness we can still buy the 2013 Yamaha lineup in 2014. Could be the beginning of the end for Yamaha if they continue to build subquality halfbreeds. ALthough, market research must indicate tha there is a market for them. Only problem is that the market does not include those who want Yamaha quality. 2015 will be a better indicator of future models. If they do not develope any new chassis, they will eventually only be an engine provider. IMO.
09nytro
What if Yamaha and ski doo got together......would it still be the same talk or no......
It's just two company's helping each other out that's it.......
You got to see more than blue guys........I was going to get a doo but this just keep me on Yamaha
YamBam
- Feb 23, 2012
- Michigan
"Halfbreed, how I learned to hate the word." "Lay your money on the ground."
Ak Yammy
Old school Cher there.YamBam said:"Halfbreed, how I learned to hate the word." "Lay your money on the ground."![]()
Well All I can say is I hope they look a bit rougher since they are proto's but am not holding my breath.
Sno Cat
YamBam said:Crazy thread. It is obvious that Yamaha has given up the old fit and finish for a cheaper quality sled. Instead of developing a chassis to meet Yamaha standards they bought AC subquality chassis and stuck their motor and clutches in it. They wanted a cheap way to get a new chassis. Anyone check to see if it has a single or double chain in it to make sure it does not break? How about a strengthened tunnel to make sure it does not bend? These were both intial quality issues, plus many more, with this chassis from AC. Initial marketing spin from Yamaha was that they would be overseeing the production in the AC manufacting plant. Hah, alot of good that did with the fit and finish. What a joke. How dumb do they think we are? Thank goodness we can still buy the 2013 Yamaha lineup in 2014. Could be the beginning of the end for Yamaha if they continue to build subquality halfbreeds. ALthough, market research must indicate tha there is a market for them. Only problem is that the market does not include those who want Yamaha quality. 2015 will be a better indicator of future models. If they do not develope any new chassis, they will eventually only be an engine provider. IMO.![]()
You've nailed it exactly. The Viper is Yamaha's transition for exiting the business of innovating, designing, engineering & building sleds. Yamaha is following their auto industry business plan of simply supplying engines only. Yamaha marketeers are heavily spinning this sled to mask its shortcomings but the fact is, the Viper is a Cat w/a Yam engine, clutches & chaincase - all else is Cat.
Nytro40th
- Sep 19, 2007
