transshop
has anyone used this kit they claim 180 hp for $1,800 sounds good.
Buckeye
- Lakes Region, NH
Fixx Power Sports
There was definitely someone who did this kit last year and spoke highly of it. I can't remember who, hopefully he is still here and will respond.
MR.HAPPY
- Sep 30, 2003
- GREAT NORTH OF... ILLINOIS?
- YAMAHA
Buckeye,
Remember he spoke like a spokesman for fix!!!
BR
BR
Buckeye
- Lakes Region, NH
He did, but I thought he was also a regular too. Don't really remember, But it does seem like alot of gains for cams and headwork.
transshop
Buckeye i talked to them there kit comes with new pistons and exhaust also sounds like alot power but have friend that gaind 30 hp with pistons and very little head work on his bike same motor.Buckeye said:He did, but I thought he was also a regular too. Don't really remember, But it does seem like alot of gains for cams and headwork.
Buckeye
- Lakes Region, NH
Fixx Power Sports
If you are changing pistons you are talking alot of labor and unless you are a 4 stroke mechanic alot of money in labor never mind what they are charging for the kit, Do they sell the kit installled and for how much? Another problem is they are in Minnesota, which is too far for most of us. If I was going to get into a total motor job I would be thinking lower compression pistons and turbo for the real power. But that is alot of money too. If they are local to you, then it might be worth considering.
transshop
Re: Fixx Power Sports
Buckeye they said $1,000 in labor. im in upstate ny if i buy there kit i will do it myself. i have alwas done all my own work. worked for GM for 15 years and have had my own trans & auto repair shop for 2 years. I dont mind getting into this motor. looks like fun. How much can i do a turbo for.Buckeye said:If you are changing pistons you are talking alot of labor and unless you are a 4 stroke mechanic alot of money in labor never mind what they are charging for the kit, Do they sell the kit installled and for how much? Another problem is they are in Minnesota, which is too far for most of us. If I was going to get into a total motor job I would be thinking lower compression pistons and turbo for the real power. But that is alot of money too. If they are local to you, then it might be worth considering.
Buckeye
- Lakes Region, NH
How much for the Turbo?
You can get a turbo from$3500 to over $5000 depending on what you want.
transshop
Re: How much for the Turbo?
Thanks i will look but all i have seen is $4500 and up who has $3500 bender told me $4500 there are a bout 4-5 hours from me might go see them.Buckeye said:You can get a turbo from$3500 to over $5000 depending on what you want.
Buckeye
- Lakes Region, NH
Bender's Stage 1 is $3896 and Stage 2 is $4496. Here is a link:
http://www.benderracing.com/rx1.htm
Jtssrx is selling one for $3500. He is working with Lightning Pro. I am sure you could email him for more info. Here is a link to his first dyno run:
http://www.rx1.info/viewtopic.php?t=1078
transshop
buceye thanks for info.
- 7K
