Which one worked? And were you able to permanently fix it? I don't think that a solution has ever been found for the flashing D light or the "push the button and nothing happens" problems.
A little background. I had pulled the sled too deep into the parking spot and backed it up. In this instance I shut it off in reverse which I have done in the past without issue.
So after reading your post I lifted up the track and spun the secondary by hand and established it was in forward gear. Then I jut blipped the throttle several times till it hit the TORS/limiter and that got the track spinning free and the light stopped flashing. Not exactly as per your post but you were the inspiration.
