Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Get them now to be ready for the fall!
Crewchief47
- Jan 16, 2006
March bump!
Just installed these. So much nicer than the Philips screws.
rupprider
Gonna hafta go into my 1999 600 Deluxe Vmax carbs. Triple with the red head,NPV. Are the older screws, to your knowledge, M4x 12 mm? Thanx RR I just hope I can crack the old ones loose!
These are a must have if you have carbs on your sled, bike or ATV. No fuss taking them off or on.
Crewchief47
- Jan 16, 2006
rupprider said:Are the older screws, to your knowledge, M4x 12 mm? Thanx RR I just hope I can crack the old ones loose!
I personally go back wrenching on Yamaha as far as a 93 Exciter SX and it had the same screws. You will be fine with the 99. If you're replacing the Phillips anyway, you can cut a slot in the head with a dremel tool with a cut off wheel and use a flat screwdriver in that, if you mess up the phillips head.
rupprider
Crewchief, thanks for the info. Making firewood now, will get into the carbs when it starts raining here.
Crewchief47
- Jan 16, 2006
Bumpity!
Any luck on screws for the carb caps?
Crewchief47
- Jan 16, 2006
I haven't sourced any direct replacements as of yet. I've seen some custom carb caps made of aluminium out there for the boost guys that look to use a more common fastener. I may look into caps instead.
I have the alu carb caps for boost from stm, they still use the screw with the shoulder. Too bad that made it with that big of hole. Need to find a buddy that can make a little bushing & then use a normal allen screw.
Crewchief47
- Jan 16, 2006
Problem with the bushing would be the chance of dropping it....hmmmmmmmmmm I'm going to have to go down to Dad's sled and pillage some parts for the summer.
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Awesome - I was just thinking last fall when I barely managed to get the phillips head screws out to clean out the pilot jets - about doing the allen head changeover - reading this thread reminded me - so I've placed my order. I have an '05 Vector - first 3 years no issues, now evey season seems to start off with plugged pilot jets - crap gas I guess - and I always drain the bowls in the Spring too.
Crewchief47
- Jan 16, 2006
Pdiddy,
Yours are all packed up, will hit the mail probably Monday because of the holiday, maybe Tuesday if the PO isn't open Monday.
Crewchief47
- Jan 16, 2006
Red, It turns out the RX and Rs use different carb caps, wasn't aware of this. I'm going to have to get a look at an RX before I go any further.
