Log4n27
Hello, I am tearing apart a 2005 Yamaha Vector and read in the manual that youy need to remove the flywheel. But the recommended flywheel puller from yamaha was 200$ which I'd rather not spend if need be. Is there any other pullers that would work just as well. Also since I was going to spilt the cases is there any useful tips out there. Thanks!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I use a standard Snap-On puller like listed in the link below. Anything similar will work.
https://shop.snapon.com/product/Master-Interchangeable-Puller-Sets/Bolt-Grip-Puller-Set/CJ2001P
