Let it Ride
For those of you who have changed your Hyfax on RX1, what was your mileage and what were the conditions of them.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
After 620 miles in early season riding. Current set has over 1200 miles and they still look good, but this was in perfect conditions.
RX1 Yooper
I was just going to make a post about this. Mainly, the screws from hell. I've got about 4500 miles on my 03. The hyfax wore almost to the line right away, then stayed there. When you get to the line, you still have plenty left. By the way, I didn't temper them, but I did bless them. I had a red set, in my garage, for about a year, and decided to change, to get the red accent. They wear better if you age them.
I used the method that I read here, about pulling the hyfax out of the rear window, and running the machine in reverse. They ripped loose from the screws, thank god. The screws were in the rails to stay. I got one out, but had to use vise grips on the other one. It turned hard, all the way out. Even putting them in was hard. I finally ground off an eigth inch to get them all the way in.
To get slides into the narrow window, you put them in vertical, then turn them 90 degrees.
Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
I have 5700 miles on my RX and it looks like the hyfax hasen't worn since break in. I carry my track with about 1" loose(hanging).
Fergie
- New Jersey-Ride Old Forge N.Y.
just changed mine, 2500 miles but it looks like i could have went another 1000. screws came out hard as they had blue locktite on them but went back in easy.
Buckeye
- Lakes Region, NH
When I bought my new slides for my 136" upgrade, my dealer gave me 2 new screws with them. That tells you what he thinks about removing the old ones.
DC5
If you heat up the screws before taking them out they will come out easiy.
Iron Dog
"I used the method that I read here, about pulling the hyfax out of the rear window, and running the machine in reverse. They ripped loose from the screws, thank god"
Yooper, I missed that post. What does running the track in reverse do? and is that AFTER you pull out old slides?
i had 3500 miles and probably could have went another 500-1000 miles.i couldnt get mine to budge.so went in from the side about 2 thirds of the way back on the rail and gently put a prybar between the slide and the rail and pulled the slide down and then out twords me .came rite out.dont try putting the new ones in this way :!:
