FYI here is a nice writeup on the Float 3 RC2 by Monster Performance:
These are the FOX FLOAT 3 RC2 piggybacks all taken apart. I figured I would disassemble some new shocks to show you the innards. The float 3 rc2 for atv's and sleds are pretty complex inside. They share the same IFP design with several ounces of oil in it as a standard coil-over BUT the air sleeves take the place of a "normal" spring.
The large gold sleeve is the main chamber. this is adjustable by the user for ride height of the machine. the smaller black cylinder, the EVOl one (extra volume) controls bottoming resistance and is also adjustable by the user. the 2 gold caps are the user adjustable air chambers. the "high pressure nitrogen" port is for me to play with, not you!
You also have 2 compression dampener clickers on the top piggyback as well as rebound control.
many customers complain of the balance or baseline of the evol rc2, where do i start? FOX's suggestions for air pressures are OK to start with for some riders. 150 psi in the evol and 50 in the main is where I suggest to start on most sleds, on the firm side. 25 to 35 in the main for off trail sleds needing more chassis roll. then, tune clickers as needed.
The standard non-piggyback floats offer just ride height control and the evol-r offer ride height, bottoming resistance and rebound adjust. I will have pic's of them apart as I find time.
The later float 2 shocks use float 3 seals. FOX in the last year or 2 has put a lot into r&d. 4 years ago I had some new RC2 fronts, felt nice but no consistency, couldn’t stand them!. FOX has changed a lot of those issues BUT still the end user must understand they are buying a tunable shock and want to use those features. otherwise they are pointless to buy.
Some say they are for the Ricky Racer, I think that’s way off base. they are intended for certain riders and certain people really.
The Float 3 is the latest generation of the prior 2 series of the last several years with the black-white float 2's changing their design a couple times too! The KASHIMA gold coating and super slick seals have greatly improved past years issues of air leaks and air pressure fluctuation.
Thank you
Ian - Monster Performance
Thank you
