Janny
- Apr 4, 2017
- Kalamazoo
- 2008 Vector LTX GT
I have a new to me 2016 Yamaha Viper XTX SE 141" with the Fox Float 3 air shocks front and back. Can anyone please recommend air pressure settings? I go about 225lbs riding weight and stick to groomed trails. thanks
65 psi in the skis and 175 psi in rear, sled must be off the ground to set pressure.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I knew the skis had to be off the ground to set pressure in front, does the skid need to be off the ground to set the rear pressure?65 psi in the skis and 175 psi in rear, sled must be off the ground to set pressure.
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
Yes.
yea
karl
- Dec 9, 2007
- Whitehorse, Yukon Territory
- 2015 Phazer XTX
here is some info that might help
Are we sure its a dual chamber? The I would do different settings.
karl
- Dec 9, 2007
- 2015 Phazer XTX
not sure about single or dual for the OP. Just found the Fox info illustrative, seems a few of us are trying to understand these air shocks.
Janny
- Apr 4, 2017
- Kalamazoo
None of my shocks are dual chamber and I think the max air in the rear at least us 150. The previous owner, who was about 180lb had the rear set at 135.
Rear I would start at 135 most likely run it more towards max if your aggressive rider. You can always take 5 lbs out at a time to get it plush until it start to bottom and then put 5lbs back.
Janny
- Apr 4, 2017
- Kalamazoo
Hey thanks Mr. Sled! This makes alot of sense in light of where the previous owner had the pressures set at. Now all I need is some snow.
Your welcome!!
