stormin norman
- Dec 11, 2007
- Southern, MN
- 2014 Yamaha Viper LTX LE
2000 Yamaha SRX 700
1999 Yamaha V max 500
1992 Yamaha V max 4
1984 Yamaha Phazer
As anyone here used or installed the Fox Float Guards on their Viper? Do they help ? Do they stay in place like they should? Any in put would be helpful. Thanks
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
I haven't used them yet but they seam to cover the hole bottom portion of the shock. the plastic there made out of is pretty thick and sturdy, they don't move at all after they are tightened down.
I ordered a set of those for my sled and they rub? They hit as soon as you tighten them down, and get worse as the shock compresses. Wondering if I got a bad set?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Ive ran them on my Nytro for years with no issues and now have a set on my Viper. I think they are a little over priced but they do add sufficient protection. The fox3 covers are also sized the same as the earlier Float 1 & 2.
The cover actually protected the shock enough to prevent significant damage when I had the a-arms torn off. The top shock cap bent over but the housing under the cover only had a small dent and didn't need replaced.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
If you have a heat gun carefully heat the base to bend them out.
Dirtbikekid1998
- Mar 3, 2013
- Maine
Myn have about a 1/4" gap between them and the shock the hole length of the compression.I ordered a set of those for my sled and they rub? They hit as soon as you tighten them down, and get worse as the shock compresses. Wondering if I got a bad set?
stormin norman
- Dec 11, 2007
- Southern, MN
2000 Yamaha SRX 700
1992 Yamaha V max 4
1984 Yamaha Phazer
Thanks for all the in put.
