dutchie
dame these are some slick looking shocks , just got a new set with the new 39 inch skinz A arms today in the mail , my season is over but gives me something to look forward to next winter on my first ride , i'm looking at putting my new ones on today , have a couple questions and need a little advice
the book says to have the chambers down and the rod end up at the top , thats just backwards from the fox float 2 i had on , i have seen pictures of guys running them with the chambers at the top ,
can you guys that have them tell me if you see any troubles with running them at the top , it would make more sense to have the chambers at the top so you wreck them if you hit something , i think would be less money to get a new dinged rod then have to replace the chambers ,
just looking for opinions and see what those who have them installed , also do any of you have them plastic guards on the rod end ,
pressure , these going on my nytro with 162 , i weigh 200 lbs , whats a good starting point for air pressure ,
thanks
thanks
From what I have read people mount them with the chambers down so it is easiers for them to adjust the air pressure on them. But dont quote me on that that is just what I have read around here.
dutchie
well here's the thing , i thought so also , but with these new ones the bushing have them only being able to mount with the chambers at the top side , the bushing on the rod end is bigger and will fit only on the bottom ,
Hmm, well it seems to me thyy are not giving you much of a choice then huh.
ruffryder
dutchie said:well here's the thing , i thought so also , but with these new ones the bushing have them only being able to mount with the chambers at the top side , the bushing on the rod end is bigger and will fit only on the bottom ,
The bushings are removable. Pop them out and change them up!
dutchie
do you run your rod ends up or the chamber ends up , and i think these bushing were pressed in to fit for the skinz front end
ruffryder
rod ends are the same for most of the float 2's, evols, and others that you get in the aftermarket.dutchie said:do you run your rod ends up or the chamber ends up , and i think these bushing were pressed in to fit for the skinz front end
You might have to take a wrench to them (twist them) but the should just pop out. I run arctic cat coilovers... well, I am going to.
Had those bushings in my floats though..
Off Trail Mike
Gone Riding!
- Dec 26, 2009
- Bathurst, NB, Canada
- MTX
dutchie:
Chamber up in my case. The only disadvatage is its more difficult to get to the adjuster. But my way of looking at it is it won't get caught by a tree either.
600km's on the skinz with the evolR with chambers up....no issues.
OTM
OTM
