woodfireman
- Feb 4, 2014
I have a 2007 phazer gt looking to upgrade the front shocks to fox floats. There are lots for sale on site from trashed artic cats and other sleds just wondering if they will fit or what size do I need for the gt. Any help would br great.
Pockets
gotta measure yours center eye to center eye and get same length floats.
xt_gt
do it. worth the upgrade. i did same thing. forget what length they are 17" maybe?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
15 5/8" i think. I have Floats with Hygear reservoirs from an Apex. A huge improvement over the base Phazer shocks.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
the gt has 17 inch shocks. i put a set of floats on my phazer from a nytro. had to make my own bushings for it cause where the shocks mount to the sled and a-arms is different sizes
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Phazer stocks are a just hair under or right at 16", MTX is 15.5". I've check and the suspension/steering has enough free movement to use 17" shocks but getting the ride hight correct might be an issue as you would have to use a lot of "sit in" which means LOW air pressure on a float.
