mikel
- Feb 22, 2013
I can't find the correct top mount bushing the one from Yamaha has the correct OD to big ID any idea where to get the right one
Mike L
Mike L
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
mike....I think the bushings from rear fox shocks from 2010 and up nytro mtx has the right ID and have a wide bushing and a narrower one for different widths. let me know the ID and width you require and I will check my shop to see I can find some to measure and locate part numbers. I ordered some when I installed a fox float shock into my nytro xtx skid a couple years ago, I used the stock rear shock bushing and the fit was perfect.....
you could also just get a bigger bushing made up for your install.
mikel
- Feb 22, 2013
mikel
- Feb 22, 2013
This is front suspension shocks
The bolt is 10mm it had a sleeve that is
14mm
The rubber bushings from Yamaha are
25mm OD that fit the top of the Fox Float 2
The ID on the rubber bushing is 20mm
So I am needing 14mm to 2mm
It would be nice if there would be 1 bushing not 3
The bushing on the bottom of the shock is 25OD the ID is 14 but the width is wider
The width is 30mm
Yamaha only shows the bolt & rubber bushing no sleeves
Thanks Mike
14mm
The width is 30mm
Thanks Mike
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
sorry buddy... shop is a f*****g mess right now and I can't find bushings. I will try and get in there this weekend and search around to find them.
cheers
cheers
