journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
A friend contacted me tonight. His 2007 Attak which has around 11,000 plus miles won’t start. Turns over but no pop at all. Said it has fresh gas in it. Ran fine last season, was stored in an enclosed trailer. Any ideas?
I may not respond much but I sent him this link so he can see the replies.
thanks!!
thanks!!
dylanjen9
Possible weak battery. Mine needs to turn over fast to start. If it turns to slow it won’t fire or start
PartnerDog
Agreed. This happened with my 06 apex this year. If it starts with a booster pack or jumpers you need a battery change. Search for battery options as you can go bigger than stock to give you more CCA.Possible weak battery. Mine needs to turn over fast to start. If it turns to slow it won’t fire or start
Pairodice
Injectors will not open if voltage is less than 12.5-12.8. Motor will spin over with less voltage. Replace the battery, they will not rebound from having low voltage unless it’s only been a few days. Plus if it dies on the trail it’s going to be a long day.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Does the fuel pump cycle? Enclosed trailers are horribly moist over the summer months if you don’t open them up and air them out. It may be something as simple as the fuel pump relax having corroded contacts, or had some condensation in it that froze with the cold winter temps.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Thanks for all the replies, hope he reads this and finds the issue. Both the low voltage and corroded relays make sense.
snogetter
thanks for all the feedback and ideasA friend contacted me tonight. His 2007 Attak which has around 11,000 plus miles won’t start. Turns over but no pop at all. Said it has fresh gas in it. Ran fine last season, was stored in an enclosed trailer. Any ideas?
thanks!!
the problem turned out to be the crank sensor
RobX-1
- Coldwater, OH
Had to do that on my 08 Apex as the crank sensor also went out. Ended up replacing the complete stator with OEM rather than attempt to wire in an aftermarket sensor. Knew I would be keeping sled so fixed it right. Not a bad job to do just be sure to also order a replacement gasket for the cover.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
How did you find out what it was?
