jojo567
- Jan 6, 2008
- UPSTATE NY
- sport-mann.com
I have 3000 miles and the lower a-arm ball joints are completly shot and warn out, sorry if this has been discussed before but wondering if anybody else has has this promblem.
Nikolai
Use the search feature, this has been covered almost once a week for the last 6 months. Lots of great info to read.
Tork
back on topic, problem is they are not really ball joints (like atutomotive style) w/ rubber seals w/ a supply of lube inside.
They are open spherical rod end bearings. Put a drop of 30 or 20w 50 wt oil on them each day you ride and your next set will last a lot longer.
jojo567
- Jan 6, 2008
- UPSTATE NY
- sport-mann.com
Tork said:Ummm let's keep our buying and selling deals honest and fair guys!!!
Tork I know and really dont understand why there was a need to do that. But anyways I have taken care of it. Thanks JOE
Tork
I trust you, earlier off topic post deleted : )
stinx
is yamaha covering the worn out ball joints?
TurboMatt
stinx said:is yamaha covering the worn out ball joints?
They replaced mine under warrenty
Alatalo
- Jan 11, 2005
I am at the end of life of my third set (two sets supplied by warranty). I have been lubricating the two last sets vs. no lubrication on the first set, but I can not say that I notice any difference at all.Tork said:Put a drop of 30 or 20w 50 wt oil on them each day you ride and your next set will last a lot longer.
If you do rough trail riding you get maximum 1000 kilometers out of a set, then the liner falls apart and the free play becomes like 2-3 millimeters.
Anyway, I have had no problems getting them replaced by warranty and when there is no more warranty I will install a set of SKF race car bearings (the required spacers FINALLY arrived from anodizing...).
AKrider
If you want a set that will last call Gueco Racing at (907) 694-1600 and ask for Danny. My stock ball joints were junk at 800 miles. My new, improved greasable ball joints at 1700+ miles and two XC races later are still tight.
jojo567
- Jan 6, 2008
- UPSTATE NY
- sport-mann.com
What did they cost you if you dont mind me asking?
Nikolai
It's around $250. More if you have your spindles welded.
- 9K
