Front End Height
RX-1 Moose
Laramie Wyoming
I need some help. I am setting up my 03 RX-1 suspension, I put the Marvin Billet shocks (which are great, spring less nitrogen) on the front and put the Fabcraft complete rear skid under my 03 Rx-1 Turbo. I stiffn the front end up with the nitrogen shocks and the front raised about 1.5" to 2" so it screwed up my rear suspention mounting points. (lots of ski pressure) I need to know the stock height of a 03 RX mountain from the ground to the front bumper, stock ski, this is how fabcraft measured for mounting points in the rear.
Right now the sled wants to submarine in the powder when not accelerating and it is trenching bad, I know all the weight is at 2 points, the ski & the rear end. I will try to raise the rear mounting point up an inch to see if it works and try to get some more distance with my limiter straps if needed but I don't really want to lower my front mounting bolts to the rear suspension because I will loose the approach angle. If I had the stock height of the front end it would help me figure out what needs to be done so I can get the sled where I want it.
Thanks ;)!
