Front heat exchanger replacement... 06 RS vector
Weldah86
Age
38
Maine
Yamaha RX vector
Well folks if it wasn't for bad luck I would have no luck at all, I had a stud pull out tonight and take out my front heat exchanger. trying to decide if I should drop it off and have it fixed or replace the heat exchanger myself.. how involved is it it looks pretty difficult to be able to get to the coolant lines on the back side of the heat exchanger. While I'm at it I'm replacing the track with another ripsaw and not studing it again. Any information on replacing that heat exchanger would be greatly appreciated thank you very much. received_193737421830659.jpeg
