fourbarrel
Building a collection one sled at a time
- Sep 23, 2004
- New Brunswick
- 2019 SRX
Can someone chime in here with the installed length for the front skid shock spring? I had a stiffer ELKA spring last year and it was too much. I couldn't get enough weight on the skis,so I'm going back to the original one for now. I saw an older thread with a Cat part number for a stiffer spring that I may try, but want to see if I can get the handling back to somewhere better than it was.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Just my opinion but your spring is not your issue. The correct way to get more ski pressure is by pulling your limiter strap up. The spring retainer should only be tightened a turn or two from loose. Using the spring for ski pressure is so backwards, defeats the purpose of how that spring needs to work. I have ditched the factory limiter straps for an adjustable limiter strap from Trac Link. So easy to make a simple adjustment based on a trail condition for ski pressure.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
Not sure what your Yammy has for a spring, but my Tcat has a dual rate spring that works good for me.
I'll look up the specs if you'd like.
Turboflash
- Mar 18, 2019
- Southern MN
Stock spring is 90/250.
Cat has another one that's 160/260. P/N 2704-229.
Agreed Denny, stiffer spring for reduced ski pressureJust my opinion but your spring is not your issue. The correct way to get more ski pressure is by pulling your limiter strap up. The spring retainer should only be tightened a turn or two from loose. Using the spring for ski pressure is so backwards, defeats the purpose of how that spring needs to work. I have ditched the factory limiter straps for an adjustable limiter strap from Trac Link. So easy to make a simple adjustment based on a trail condition for ski pressure.
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I'm putting the stock spring back on my '19 SRX and would like to have the installed length of it.My service manual makes no mention of that measurement.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Install it at minimum preload and adjust for your ride quality preference from there.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
If you weigh more than 240 dressed, the 160/260 spring works well.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
A few more batches of Christmas cookies and I'll be buying that spring.If you weigh more than 240 dressed, the 160/260 spring works well.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I'm 220 and I use the 160/260 spring. Works great.
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
Wish they had a dual rate spring in-between the 90-250 and 160-260.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I just put that 160-260 spring in my LTX Sidewinder. It is actually shorter than the stock spring by about an inch. Got to ride about 50 miles Saturday and I noticed it felt a little more lively than before only running about 2 turns from loose so far. There is another spring from stingray which I have in my viper which may be in between but don't know personally.
Turboflash
- Mar 18, 2019
- Southern MN
Me too! Like a 120 or 130/250Wish they had a dual rate spring in-between the 90-250 and 160-260.
