mn_anderson
- Jul 16, 2020
- Alexandria MN
- Nytro MTX SE 153
Hi, I tried looking through my manual but didn't see the spec for the hole with the bushings for the ski at the lower end of the spindle? Mine are shot and I'm taking them with me to work tomorrow to check them over, but it would be nice to know what the hole spec is so I know if the spindles are ok. Anyone know the hole spec or a source to find out? Thanks.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This is the UP Bushman nytro ski bushing.
I dont have measurements for the spindle but this might help. Measured in inches.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
This set up works great for worn spindle holes.
He says to loctite the bushing in when spindles are worn.
mn_anderson
- Jul 16, 2020
- Alexandria MN
- Nytro MTX SE 153
Thank you, this will help. Im guessing that my wear is not all from the bushing.. so Ill have to see how bad it is.This set up works great for worn spindle holes.
Dr. FeeLGooD
UP Bushman nytro ski bushing set is the only real fix worth doing that I am aware of. Stock bushings are an embarrassment.
