Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I am replacing the stock skis with Tuners but, when I went to pull everything apart the collars that go through the spindles that the ski bolt goes through were stuck in each spindle. I had to use a press to get them out. After cleaning everything up the collar is now slightly sloppy inside the spindle. I notice there are some brass or oil-lite bushing inside the spindles. Can they be replaced? I dont see them on the parts diagram?
Also, what is the nominal diameter of the collar that goes through the spindle? Maybe it is now undersized which is causing the sloppiness.
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
90384-16N51-00 Bi Metal bushings two per spindle.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Yes I replaced mine after 2500 miles.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Just need to press them out.
MS
MS
mnman309
Ulmer sells them too
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
My '09 RTX has just over 1k miles- spindle bushings shot.
Went with Ulmer's, $35 + 2 new stock collars slathered in never seize
erick jr charbonneau
- Nov 25, 2019
- Gatineau
- Yamaha nytro xtx 2011
Hey there i dont fine nothing ulmers ??
Tanks guys
Tanks guys
- 21K
