Front suspension height
Radar22
Ontario, Canada
Hey guys,
I was on a trip this past week and another guy in our group had a 2010 fx Nytro and when we put mine beside it (2010 rtx) his sat higher in the front end then mine. He has the gyrt spring shocks and I have the fox shocks. Same year. We also notice mine sat higher in the back end then his did... Just wondering if the front end is lower because of suspension settings or is it because if the length of the shocks? His shocks seemed to be a little longer than mine.. Anyone ever notice this before? Everything is stock on both machines..
He probably has his springs cranked up. One of the things the Hygear setup does is lowering the front end, it improves the handling dramatically.
He did have the spring let all the way out. What is the hygear your referring to? Mine did feel more planted in the skis
Hygear triple rate springs (Twisted) which lowered my 2010 XTX by 1 1/2" greatly improving the cornering ability!
My buddie has a 08 rtx with fox,mines a 09 xtx with gytr mine sits higher than his also mine seems to move alot easier if you stand on them and rock side to side
mike3577.....the front shocks on your 09 xtx are longer than your buddies rtx
