Front suspension not seating evenly
shockwave
St Paul d'abbotsford Québec
Canada
09 Phazer RTX
LOCATION
I notice this last year and I wonder if that is normal or not.
My right Fox float is always more sag or compresse then the left one. Close to an inch. Is tant normal? Or the should be both be sag at the same level?
they should be even. i took the floats off of the 09 rtx and put gytr coilovers a guy gave me as the left one on mine was stuck when i got it. as i bought in summer and did not ride it, i took it as a lesson learned along with the bent lower control arm it caused.
Check air pressure off the ground also.
That is the first thing that I did. They are the same. They were rebuilt last year. I just wonder what cause this? Could something could be bent and cause more pressure on the right site?
Swaybar could be bent or even a a-arm.
