04rxwarrior06
on my 04 rx warrior for some reason my fuel guage works #*$&@ backwards all of the sudden, i didnt touch any wireing or anything. when the tank is full it reads empty and my warning indicator and fuel light are on and when its empty it reads half or almsost full.... any ideas what went wrong here?
sending unit installed upside down.
have you done any tank work lately?
04rxwarrior06
nope not a thing changed the oil.
Len Todd
Maybe the sending unit has failed. Here are the resistance specs on the fuel sending unit.
Might want to check the connector to ensure a good connection, first. Then measure using an ohm meter. Should be black and green wires. Measure right at the connector closest to the fuel sending unit. The connector should be close to the fuel tank.
Fuel sender resistance
Out of specification = Replace.
Fuel sender resistance (full): 4 - 10 ohms at 20C (68F)
Fuel sender resistance (empty): 90 - 100 ohms at 20C (68F)
04rxwarrior06
im not sure if that is the case, it seems to be perfectly opposite.... it seems like the wires got switched, but i havent touched a thing. the only thing that has happend was before i went on the first trail ride of the year (this weekend) someone left the key on and the battery was dead when i went to change the oil but i used a good batery charger designed for smaller baterys and everything works and it runs fine except for the fue leavel.
Len Todd
Check my previous post. I put in the Fuel Sending unit testing specs. Also you might want to check the connector at the back of the gage pod.
04rxwarrior06
okay that sounds like a good start for me thanks alot i will give it a try tomorow and let you know how i make out.
04rxwarrior06
i pulled the sending unit out today, moved it manually while the sled was running and put it back in the way it was working so the guage woked correctly and it works fine now haha
