I filled my sled up with gas and the fuel pic. is flashing, along with the fuel gauge.The yellow ! light is flashing also . Any help is greatly appreciated. The sled runs great though
i hope you're running premium. my sled did similar after dumping in farm gas (85octane). i've herd that low octane isn't good for the injectors so be careful
are any error codes flashing? maybe you have a stickey filter? or pump? did you leave old gas in it durring storage? stale gas will leave sediment behind wich can possibly cause your injectors to get plugged up, maybe there is always the possibility that you got some condensation in the tank some how? theres a tone of things and variables that can set off these sensors.
no error codes are flashing.I'm not sure but i had about 2 gal. of gas in the tank from last year.I change the oil put it all back together and started it and everything was fine.Then I decided to relocate the gauge pod and all I did to that was unbolt it flip it over and put it back together. So then i started it and thats when it started doing this .Since then I added 4 gal. of 93 octane and no change. Thanks again for any help.
