I suspect the stock fuel map on the 4/ is infinite or continuous demand - jetted OK in other words …or is it? Not is it jetting to optimum - but it is a continuous curve.
Of the aftermarket products used to fool the map after the box – which one has the most adjustment?
I’m trying to visualize…so the stock fuel map line is continuous… and the aftermarket devices may interrupt at say 5 points. This would mean you are going from stock map then adjusting the map at 5 points so the fuel curve..total… may actually be better – but the line or fuel graph line would not be linear –right?
The aftermarket devices are safe and easy – but who would have the ability to modify the entire factory curve?
