S samrx1 Veteran Joined Mar 12, 2005 Messages 42 Reaction score 0 Points 686 Location montreal québec.. canada Jan 25, 2009 #1 at 15 to 20 lb + boost . what is the best fuel pressure on fuel regulator. for rx1. carbs. thanks. Ted Jannetty TY 4 Stroke God Joined Nov 24, 2003 Messages 2,010 Reaction score 15 Points 1,198 Location Waterbury Ct. Website www.jannettyracing.com Jan 25, 2009 #2 samrx1 said: at 15 to 20 lb + boost . what is the best fuel pressure on fuel regulator. for rx1. carbs. thanks. Click to expand... base Fuel pressure is the same regarless of boost 4 psi. As boost increases fuel pressure needs to remain 4 psi above boost at a 1;1 ratio. S samrx1 Veteran Joined Mar 12, 2005 Messages 42 Reaction score 0 Points 686 Location montreal québec.. canada Jan 25, 2009 #3 thank you for your answer ted.. i appreciate. You must log in or register to reply here. Similar threads checking fuel pressure srxguy Jan 15, 2008 4 Stroke Turbos/Supercharger Replies 2 Views 1K Jan 15, 2008 srxguy Apex high boost fuel pressure peteracing Nov 8, 2006 4 Stroke Turbos/Supercharger 2 Replies 20 Views 4K Nov 17, 2006 Anonymous A Nytro fuel pressure regulator location? 347strokin Dec 27, 2008 4 Stroke Turbos/Supercharger Replies 13 Views 4K Dec 27, 2008 347strokin R Fuel pressure on turbos RED Sep 13, 2004 4 Stroke Turbos/Supercharger Replies 1 Views 2K Sep 13, 2004 peteracing 9 question on fuel pressure on fuel pressure regulater 925rotax Jan 7, 2010 4 Stroke Turbos/Supercharger Replies 3 Views 1K Jan 7, 2010 925rotax 9 Share: Facebook Bluesky LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link
