ratman
does anyone have a picture of where the fuel pump relay is?
Lower right side with you sitting on it.Right behind ECU which is a black plastic box about 4"x4"x1" and held on with a rubber strap.Its all easy to see if you remove the lower sidepanel.There is 3 or 4 relays all the same.One is the fuel pump relay.
