Fuel relay sticking in cold weather fix
BombaPolaYama said:
yamahas said:
Yup I have the "updated" relay for the phazer in my hands right now and the only way i can see moisture getting in is from where the prongs are, di-electric grease seems to me like it would really help.
What relay exactly are you referring to (there is more than one I believe)? I had one that needed replacing the 2nd season but don't know if it was updated or not.
thanks,
The fuel pump relay was the one I was referring to.
the fuel injection relay is located in the four relay stack in the nose of the sled, left of the steering post. It is the third relay from the front.
Fuel system relay
hi guys,
i realize i'm not totally in the right category here but i'm guessing it'll be quite similar. are these relays located under or behind the battery on the venture light? also, my dealer in st. john's, nl has never heard of the load control relay listed in the "lighting system"?
thoughts and comments welcome..
cheers,
ap
