FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
Thinking about the Fuse Block Relocate kit from Barn of Parts. Images borrowed from ArcticChat.
The factory location is more than poor. However the location may be for a reason. Like less vibration on the fuses & relays. Will the belt guard mount induce too much vibration on the fuse block?
Who has some run time on this set up?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I bolted mine right to the belt guard as with my turbo I could not use the adapter plate. Four thousand kms and not an issue at all. I would move yours.
Yes no issues. It's a good mod just in case.
SounderMN
- Sep 26, 2011
- Minneapolis, MN
- 2015 Yamaha Viper LTX DX
I moved mine, and have about 1500 miles on it. No issues. I did not buy the kit. I moved the existing bracket and riveted it onto the belt guard. Existing harness is long enough.
snowhite
I too came across this thread and did likewise, moved the block to the guard it's solid (riveted) to the chassis, can't ask for more of a solid mount. Also much easier to get to right?
