Fuse Location
HydrogenCyanide
Fort Erie
Canada
2006 Yamaha RS Nytro
2006 Yamaha Apex
Where is the fuse box located on a 2016 viper. I just bought this 2016 ZR7000 over the summer and got out for my first ride today. Niether handlebar warmer, thumb warmer or seat are working. I assume it must be the fuse. Any other ideas? Where exactly is this fuse located?
Above the primary clutch. Easier to see if you take the hood off.
Many here have installed the Barn of Parts fuse/relay relocate kit which moves them to the clutch guard for easier access.... also includes a legend showing which ones do what.
I have attached a photo of the fuse location and use. I printed out a copy of this and taped it to the inside left side panel for reference if needed.
Thanks everyone. I changed the fuse and they worked for awhile abs now stopped working. I have a feeling the fuse has blown again. Any ideas why the fuse would be blowing? It does have heated seat as well which is less important to me.
Take the hood off and move the fuse box from the coolant bottle that you cant really get to and mount it on the belt guard. Wires are long enough to do it. As to why you keep blowing a fuse, the answer is that there is a short somewhere. If they all go out, then check your switches. If you need elements, go to a Cat dealer and ask for the ones for a 12 pro cross. Exactly the same, half the price.
