Adam 12
- Mar 12, 2013
I have an 08 fx nytro and it sounds and feels like its cogging..could it be something else besides a loose track?....also the Speedo is not reading anything.....
its on but no reading????
09nytro
Check your drive shaft bearing....
radianguy
- Jan 1, 2007
It might be the drive shaft bearing, speedo sensor is on the end of that shaft. Pull secondary clutch to inspect the bearing.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I think it is either the bearing, gear fell off, or bad speedo.
I bet you see code 84?
sgilbert
reach up in tunnel behind the speedo bearing, if blood runs down your arm, there is your problem
- 9K
