Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I hope I got one of the 3000 hp ones!
Alatalo
- Jan 11, 2005
Daranello said:wont they produce allot more after the dreaded break in?
More experiences from the MCX dyno:
Once the piston rings seal, approx. 15 minutes after first started, the power output does not increase.
Trust me, they have checked this...
Daranello
Suspended
Alatalo said:Daranello said:wont they produce allot more after the dreaded break in?
So why did my apex just get faster and faster as the miles where put on
Alatalo
- Jan 11, 2005
Because every other friction point in your sled, like driveline bearings and track, loosened up...?Daranello said:So why did my apex just get faster and faster as the miles where put on
Modern sportsbike engines are built to unbelievable narrow tolerances. Because of this, long break in procedures rarely improve the power output. Once the piston rings seal and the piston ring blow by stops (after approximately 15 minutes of running), these engines produce more or less full power for the next couple of hundred thousand miles...Modern Superbike, Supersport and Superstock engines (based on these production engines) are run 15-30 minutes in the dyno, then they are considered to be broken in and race ready...
- 10K
