MrSled Site Admin/CEO Staff member Joined Apr 13, 2003 Messages 21,870 Reaction score 9,470 Points 2,103 Location Schofield, WI Website www.totallyamaha.com Country USA Snowmobile 2020 Sidewinder SRX Dec 23, 2012 #1 Clutching How to install a Ulmer Clutch kit Torque Specs Drive Shaft Torque Specs Electrical Starter System trouble shooting Nytro Fault Codes and Relay Location Install Vector Gauge on Nytro Install Vector Gauge on Nytro Ver2 How to test my AEM Air Fuel Gauge Fluids Oil Change Instructions Oil Pressure-Diagnosing engine after loss of oil Fuel Mileage Fuel Level in Tank for each bar on gauge pod Fuel Mileage Reports from TY Members Real World Fuel Mileage Fuel Tank Options Clear Tank: extra fuel and installation with pictures Extra Fuel Tank Removing Fuel Tank Sleeve FX Nytro Miscellaneous General Bearing Maintenance Bearings: Jackshaft and Trackshaft Feedback - Apex Owners Switched to Nytro Feedback - Phazer Owners Switched to Nytro Owner Photos Sled Weight and Horse Power numbers Top Speed Who Loves Their Nytro! Wire Rub Fix with Picture Yamaha Technical Manual On-Line Order web site Handlebars Handwarmer Fix from Bluballer Handwarmer Poll Handwarmer Resistance Tests on 09 Models Kill and Dimmer switch Part #'s Headlight Bulb Size Headlight beam adjustment procedure Hid vs Halogen Hyfax, Belts Adding wheels to XTX for better hyfax wear Belt Options Hyfax wear opinions Left Boot Syndrome Fix for Wet Left Boot Syndrome Wet Left Boot Discussion Modifications Under Tunnel Exhaust Seat Mod Front End Ball Joint Install Heated Shield Hook Up Removing heat exchanger with pictures Spare Belt Holder Tether Installation Instructions with Pictures Tool bag Ride Report Alaska Early Season 2007 Ride Report and Second Ride Report Member Test Ride Report Official TY Ride Review of 2008 FX Nytro Yellowknife's Season Ride Report Shocks Adjusting GYTR Dual-Clicker shocks Fox Floats: Pros and Cons Fox Float PSI Setting Survey Skis Mod to install a Polaris Gripper Skis Best Skis? C&A's C&A's with picture of mounts Suspension XTX Suspension Setting 08 to 09 Suspension Changes 09 Changes Crucial Suspension Changes to Make Your Nytro Rock! Limiter Strap Fix Need help getting a softer ride RTX Suspension Settings - I nailed it! Suspension Settings That May Help FX Nytro settings POST YOURS Suspension Troubleshooting Chart from Snowest Magazine Tracks Understanding Track Length and Pitches Adding Extrovert Drivers Track or Gear Change Instructions with Pictures Track or Gear Change 2nd Thread Track Options Windshields Pictures of tall windshield and side deflectors XTX Specific Threads Suspension Settings Last edited: Apr 3, 2016 B bholmlate Expert Joined Aug 19, 2008 Messages 318 Reaction score 3 Points 433 Location Reno Nevada Jan 2, 2013 #2 MrSled Thank you for taking the time to put all this stuff together in one spot. Sure makes it easy for the rest of us MrSled Site Admin/CEO Staff member Joined Apr 13, 2003 Messages 21,870 Reaction score 9,470 Points 2,103 Location Schofield, WI Website www.totallyamaha.com Country USA Snowmobile 2020 Sidewinder SRX Jan 2, 2013 #3 bholmlate said: MrSled Thank you for taking the time to put all this stuff together in one spot. Sure makes it easy for the rest of us Click to expand... Your welcome, that Moderators do a lot of this too... always thank them as well. You must log in or register to reply here. Similar threads Sticky FX Nytro FAQ Swiss Sledder May 5, 2008 FX Nytro General Talk 2 Replies 24 Views 139K Aug 20, 2020 maim H 08 FX Nytro Opinion HuckKnows Aug 29, 2012 FX Nytro Mountain Talk Replies 7 Views 2K Sep 13, 2012 KINS K Impressive weight if the info is correct on FX Nytro. Superman Feb 26, 2007 General Yamaha Discussion 2 Replies 23 Views 5K Mar 4, 2007 Dano D Wheel kit on Fx Nytro XTX FX NYTRO XTX 144 Mar 6, 2013 FX Nytro General Talk Replies 6 Views 3K Mar 7, 2013 alsops S Turbos for Nytros - Buyers Guide (work in progress) Scheidl Nov 13, 2009 4 Stroke Turbos/Supercharger Replies 14 Views 9K Sep 4, 2010 **sj** Share: Facebook Bluesky LinkedIn Reddit Pinterest Tumblr WhatsApp Email Share Link
