sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Now that more guys own nytros and there are many more miles logged on these sleds do guys have input on suspension setups for FX, RTX, RTX SE, and XTX? If you do can you add your weight without gear, riding style, and skis? I'm looking for a good baseline for cornering, without a lot of bottoming on a 2010 rtx with hygear resi's and c&a Xtx skis @235lbs with regular clothes on. Which I know will be different then my last 08 rtx.... Thanks guy
00-NUKE
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
When you guys say your compression and rebound settings are "6 clicks out" im assuming your meaning that they are truned fully closed in the clockwise direction then backed out 6 turns?
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
yes thats correct
rippintheyammi
- Oct 29, 2021
- 2010 Yamaha Nytro RTX SE
I have a 2010 RTX SE that I just picked up but don't have excel on my Mac. Is it possible to get a PDF posted? There isn't any snow but I want to make sure i'm set up when there is! ThanksLotsa setting for the Nytros and hopefully we can all help each other out. I'm asking for all the FX Nytro owners (base, RTX, RTX SE, XTX, etc.) here to write down what settings for each of the suspension components they are trying out, their riding style and weight.
Thanks to Crewchief47 for setting up an XLS program for all the settings. There's even a little comment box for any info you can share. Download the file, add your info, save it, post it and I'll try to update it regularly in the first post.
rippintheyammi
- Oct 29, 2021
Do you have a PDF of the RTX SE settings?Changes have been made to the excel file. Any other ideas are welcome, as long as it doesn't get too big. I'll add model specific sheets as it starts to fill up.
smokingcrater
If you have google you can open it with sheets.google.com also.
- 6K
- 16K
