Phyxius74
1nc 2000 said:What is the sled next to it? Looks like different A arms than the nytro's we have.
2012 FX Nytro X-Ride (MTX 153) with SPG Concept A-arms and LOTS of other stuff.
ttx
will those ttx front ohlins work on a 42" SPG front end do the ohlins have spherical ends.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Im gonna test ride the ttx this weekend
The shocks are sick!!!!! too bad they dont get ride of the silly Yamaha rear torque arm as well and they would have a good set up.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Now that was a sweet ride. It took the bumps like nothing.
I want those shocks!
Other than that i test rode the m-ride, with the ascent track, which also was sweet.
Alatalo
- Jan 11, 2005
Re: ttx
A friend of mine is running these exact shocks with custom made bearing spacers in his MTX with the narrow Skinz front end. The maximum angle of the spherical bearing is sufficient, but the bearing spacers will touch the cylinder head of the shock before the spherical bearing reaches the maximum angle. Thus the custom made bearing spacers.
However, no clue if this will work in the 42" version.
Yes, these shocks have spherical bearings in top as well as bottom. Though, please note that spherical bearings is not the only thing needed in order to use the Skinz front end. You also need a spherical bearing with possibility for quite a big misalignment angle.srx900 said:will those ttx front ohlins work on a 42" SPG front end do the ohlins have spherical ends.
