LeSerpent
Hi,
This is my setup for my Garmin Montana 700i mount.
Very simple and low cost.
Ram mount # RAM-B-247U-15.
If it can help anyone.
race24x
Is that the only part that you bought? Any closer ups of the way you mounted on handlebars
LeSerpent
Yes, 2 parts only.Is that the only part that you bought? Any closer ups of the way you mounted on handlebars
Let me know if you need more info.
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
I did the same thing. I think i'm using a 4 inch arm, and I cut a half circle out of the handle bar pad to help keep it centered. It stays in place well if it is tight enough. I like the setup as it is easy to glance at while moving and I can take it in with me easily if I need to. I also added another power port to plug in it with
Clintww
- Mar 6, 2022
- Central MN
- MN
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
I had mine mounted to the riser like that but found it hard to look at except when stopped. I moved it to above the factory gauges and now I can glance at it when coming to intersections with out taking my eyes off the trail. I used a 1” Ram ball mount on a adhesive base and stuck it right behind the factory gauge.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I have the BOP GPS mount, ant it works great. Right above the gauges. Details here: https://ty4stroke.com/threads/custom-gps-mounting.164038/#post-1577996
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This!
Arctic cat dash caddy
That would be mine with the Cat Mid-LXR windshield. Which model gps is that ? It seems to fit perfectly on the dash caddy.
ty4stroke.com
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
This is what I’m thinking but with the XT2 if the new guage doesn’t pan out with a retrofit to our sidewinders.This!
That would be mine with the Cat Mid-LXR windshield. Which model gps is that ? It seems to fit perfectly on the dash caddy.ty4stroke.com
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I installed the dash caddy last year and mounted my 8" tablet on it.This is what I’m thinking but with the XT2 if the new guage doesn’t pan out with a retrofit to our sidewinders.
Works great and a great place to carry my hat for when going inside the warming areas.
stgdz
- Mar 27, 2021
- Buffalo MN
Anyone have any advice on how to mount the Garmin car gps units? The mount is a circular mount and it should have a simple mount but I'm stumped on this one on how to keep it secure and from flying off.This!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I drilled 4 holes in the door of the dash caddy.
The holes are the bolt pattern of the ram mount on the back of my tablet holder.
Just bolted my tablet holder to door.
super1c
Moderator
- Apr 10, 2010
It won’t come off. Ran all this season with that mount. It’s surprising how solid and secure it is.Anyone have any advice on how to mount the Garmin car gps units? The mount is a circular mount and it should have a simple mount but I'm stumped on this one on how to keep it secure and from flying off.
super1c
Moderator
- Apr 10, 2010
- 6K
