fourbarrel
Building a collection one sled at a time
- Sep 23, 2004
- New Brunswick
- 2019 SRX
What info is stored in the gauge cluster? I have some damage to the back of mine and it wont lock back into the mounting hole due to a piece missing from the round locking mechanism.If I have to change the gauge to another one will I have to take it to a dealer to have the info like mileage downloaded to the new one?Or is it possible to fix the locking mechanism on the back of the gauge cluster? Once I get it out I can take a pic of the missing piece but it is missing a piece from the bottom section that locks into the hood.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Mileage is stored in the gauge. Hours are stored in the ecu. So the gauge will read zero if new or if you buy a used, whatever kms are on that gauge.
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
Another thought, you could swap the guts from your original to the undamaged housing.
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
Well that was another question I should have posted here as well and thanks for reminding me.How big a job is it to take the housing apart? I haven't even looked at it that closely yet.Another thought, you could swap the guts from your original to the undamaged housing.
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
I believe the gauges are sealed. Don’t think it comes apart without breaking it. You could just silicone your gauge in. It doesn’t really need to come out.Well that was another question I should have posted here as well and thanks for reminding me.How big a job is it to take the housing apart? I haven't even looked at it that closely yet.
If you do need a used gage cluster, I do have one from a 2019 winder—- 3800 miles—- but I would find a way to make yours work—- the silicone idea should be good— Tod
fourbarrel
- Sep 23, 2004
- New Brunswick
- 2019 SRX
I managed to find the broken piece of my gauge lock ring and plastic welded it back together. It needs a little tweaking but it should work.If you do need a used gage cluster, I do have one from a 2019 winder—- 3800 miles—- but I would find a way to make yours work—- the silicone idea should be good— Tod
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Plastic welding works amazingly well.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Or fashion a JB Weld repair. I had to repair the tab on my Apex headlight from taking a pretty huge unexpected, and luckily successful, flight once and lo and behold BOP actually makes a repair kit for that. Meaning that a common weak point may have been solved by some other Macguyver somewhere already.
- 8K
