chadman
Can I put a 23 tooth gear on the top and not have to change the chain on my 2012 apex?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
12 apex standard or xtx?
chadman
Standard apex.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You will have to change the chain as well.
24/37 gearing is stock and has a 70 link chain.
23/37 gearing requiers a 68 link chain.
chadman
What does a chain cost with the 23 tooth gear?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
i might be intrested in trading chain and gear even up from my xtx but i hear i may not be happy with the taller gear
chiefsledhead
The secret number combination is to add the number of teeth on both sprokets. If the total is 60 or less, then you need a 68 link chain. If the sum of the two numbers is 61 or more, you need the 70 link chain.
chadman
Thanks for the info, I didn't know that.
