newrx1guy
Anybody drop one tooth on top gear on a rx1?I see the apex guys are gearing down one on top.Does this help a Rx1 any Thanks
LazyBastard
I went way more than 1 on top.
dropped one on top, added 4 on bottom.
15% more bottom end - the feeling is unreal. Requires overdrive.
You can go 10% without overdrive.
Top end is about the same.
sdracer
The best all around gear is the 23 for trail riding.
LazyBastard
Nah, thats just whats most popular. Reason is that its better than stock and you get to keep the stock chain.
wantboost
lazy is yours a good gear setup for 1000ft?
LazyBastard
Um, YES. As long as you have the traction to back it up.
Charged RTX
LB You seem to be the gear down guru. I currently run a 23 38 in my RTX but have a 39 bottom that I was thinking if adding. I am going to run an XS 805 this year and have a secondary that will overdrive. I do a lot of lake running but I am not looking for just top speed. I do mostly 1000 to 2000 foot drags on snow and ice. I know it is not a big change but what do you think? I have a 1" track with good studs which hooks well. I think I will be at around 165 to 170 HP this year.
LazyBastard
Lets say you're running nearly 15% more power... geared down about 2.5%, overdrive about 5% giving you about 2.5% more top end potential before you start to overrev. Now of course, 15% more power does NOT translate to 15% more speed, so you're probably going to run close here. I give you a 50% chance of overreving by putting in that 39 tooth gear. It should definitely help in the drags though....
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Lazybastard is right on.
I have geared down my turbo sled 1 tooth to 23/38, running at 285 HP. A stocker benefits from gearing down even further than 1 tooth that's for sure.
In my '05 stocker I run 21/38, this sled is not geared for top end (I have my turbo for that) but for the tight and twisted trails. I even haul timber out of the forest with the '05, it pulls whatever I can load into my timber sled, no problem. Throttle response is vicked on the '05.
Mikey
- Thunder Bay Ontario
- 03 RX-1
LB where does the speedo end up on this ? I know the stock setup the speedo is off like 10-15% when we gear down what happens to the reading on the speedo? I would like to correct it if I can. I am running 23/38 with 8 tooth drivers.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Speedo reading is taken off the drive aksel so gearing down will not affect speedo readings. To correct this your can grind off 1 tooth of the speedo pickup, this will get you close, still reading a few % high.
The 8 tooth drivers (if driver outer diameter is less than stock) will affect the speedo readings. How much I don't know, have to do the math on this one
LazyBastard
With 8 tooth drivers, your reading will be considerably more off than stock.Mikey said:LB where does the speedo end up on this ? I know the stock setup the speedo is off like 10-15% when we gear down what happens to the reading on the speedo? I would like to correct it if I can. I am running 23/38 with 8 tooth drivers.
As for it being 10-15% off stock, nope, not THAT far. Some people will have readings that are way off, but thats because the track slips. I once saw a reading of 135 and I wasn't going more than about 50. I've also had a reading on the gun of 118 with a speedo reading of 125 --- thats less than 6% off, which is more accurate than my truck. My truck is actually 7% off (also reads high).
black john
speedo
yep with the 8 tooth they would be even farther out but with 10 tooth drivers there dead on
and you even get a better track angle and the speed off the trail in the snow picks up .
Mikey
- 03 RX-1
Anyone ever try grinding two teeth off the relucter?
black john
gear
yes i did before going to the 10 tooth drivers and two teeth was very close . with in 1-2 mph . after installing the lager drivers i had to put the stock gear back and i was a little closer yet . and i had to gear down for the drivers as well 24-42.
