porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
recently been getting covered with snow from the back of the sled in any condition really.
My jacket/ helmet, rear of seat, tail light area.
Wife almost ran into me not being able to see the brake light, don't need that happening.
Seen someone here had used a Viper snow flap sorta effectively, wondering if it was a '14 or what?
I gotta try something....
Michigandir
- Nov 28, 2014
- Michigan
- 2013 Yamaha nytro rtx
Did you do the tunnel block off. It's all coming from the hole behind your seat.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
I have an enclosed tunnel plate covering the exhaust.
Longer flap will definitely help. I had a really bad issue with snow on my back with a cut down stock flap. Put a long skins flap on there and it is much better now.
MNBlizzard
Wish I had your problem...trails havent even been groomed here!
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Does your snow flap hang straight down or close to it??? Try bending it out a bit, I think you get a wind swirling effect like in the bed of a pick up. With the flap bent out slightly I feel it lets that turbulent air escape..
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Tony, it's sticking out there some but think it's just short.
MnBlizzard, we've been grooming almost nightly for 2 weeks now- the 1'+ recently has helped a lot. Need more!
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
good job on the grooming!!!
shadow44
I put a 2014 Viper snow flap on my 08 RTX, I've noticed a big difference...no snow on my back. I do still get some snow on the tail light but I got into the habit of wiping it off every time I stop. Here's a pic, and keep in mind I have the GYTR bumper for clearance. The flap also required trimming and new holes drilled to mount it.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Thanks Shadow,
How is it being so rigid when backing up, doesn't crease in or ??
I have a Skinz, plenty of room also.
shadow44
Thanks Shadow,
No issues so far , it seems pretty rigid but flexs fine when I pull it of my truck ramp and hasn't cracked or anything. So far so good. When I back up it also stays rigid and doesn't go up into the track.
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
whats the width and height on this one?
EDIT
found it.
It is 15 1/4 inch wide at the very top where it rivets on. Then, about three inches down, it widens to 18". It is about 21" long from top to bottom
EDIT
found it.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Thanks for the info-
My dealer has a new/ take off for $35, gonna give it a try.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Just rode 200 miles this wkend w my new '15 Viper snow flap and stock bumper...no snow on my back...and buddies can see my break light now too!!
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
It's on, trial run tomorrow night
- 7K
- 20K
- 7K
