Garnotte
- Dec 24, 2014
- Nytro
I have a nytro 162 2012 with fox float, who ride like crap... I swap the front shock with the GYTR, now the front end ride a lot better, much more smoother on the "trail"
For the back, with coil-over could fit there? There is any chance I can find a equal lengh shock from an another sled? The others nytro, run different suspension, they don't use coil-over except for the center shock.
Any idea?
Any idea?
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
Exit or Hygear's Axis shocks will probably will more than likely be able to build you shocks that will fit. They will be expensive though.
It will be cheaper to call a good shock shop and have the rear shocks rebuilt/upgraded/revalved to your liking. Early air shocks don't perform as the newer/updated ones.
Garnotte
- Dec 24, 2014
- Nytro
I know custom built shock could be the the best way, but I don't want to put near 2000$ on shocks
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
A single center non adjustable coilover is like 4-500
Garnotte
- Dec 24, 2014
- Nytro
Maybe in the USA, but not here in canada.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Right from hygear. Axis is that range. Idk about shipping tho.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
cheers
